- donkeychomp
Some weird shock mount??
- donkeychomp
Wow way off...it's on the LJ so not a Bland Rover cheat or anything...
I thought it was and as I've never spent any time on one I'm just throwing out guesses. You say blandy like I've owned one or somethingdonkeychomp wrote:Wow way off...it's on the LJ so not a Bland Rover cheat or anything...
![Embarrassed :oops:](./images/smilies/icon_redface.gif)
![hahaha :hahaha:](./images/smilies/laughing2.gif)
- Fwb2700
It's a high tensile bolt of some kind with s rubber bushing
Could be a transfer case bolt.
Has no hexagonal head though.
Could also be a lead spring bolt
- donkeychomp
- Fwb2700
My answer not close enough? I have never even seen a lj before so I thought was pretty damn good. Only reason I guessed those is due to the rating on the bolt had to be something strong.
Could also be a gearbox mount bolt possibilly.
I am going to say transfer case no idea why other then it's more likely to me that a suspension bolt would have a hexagonal head.
- donkeychomp
Give that man a cookie.
Transfer case mounting bolt!
- Fwb2700
Can you post a zoomed out pic please interested to see it
- donkeychomp
I will...trying to get the damn middle prop off so I'll be under it again soon enough.
