Electronic parts
Niall
Electronic parts
Post by Niall » Thu Jun 04, 2015 1:38 pm
Hi
I have a Suzuki grand vitara 2001 2ltr petrol.
I need to replace the Throttle Position Sensor and Air Mass Sensor.
I've tried a Suzuki dealer who will charge a fortune to replace the items.
I wonder if anyone can recommend/suggest a second hand source for the parts.
Many thanks and living in hope.
Niall
France
niall.cooke@nordnet.fr
Re: Electronic parts
Post by Darrell » Thu Jun 04, 2015 11:22 pm
"Google" the part numbers, should find quite a few after-market company's selling them a lot cheaper than genuine Suzuki.
Untitled gv.jpg (239.35 KiB) Viewed 3838 times
Rhinoman
Post by Rhinoman » Sat Jun 06, 2015 8:18 pm
I think its unlikely that you need to replace both, I would check for a wiring issue first. When a scan tool says there is a fault then it means that there is a fault somewhere in the circuit, not necessarily a failed part. can you read live data? if so what readings do you get from the sensors?
