Sj 410 project
Re: Sj 410 project
Not updated this a while, although only started getting back into it last week, these posts are copied from another forum so bare with me
Re: Sj 410 project
Once i cut out the old arch....
Ignore all the tac welds along the outer arch, I wish i had tac'd it on the inside, and it'll be grinding them all off, as i've now seem welded along the inside of the wing and i'll get some photos of that today...
I was abit hesitant without trying to remake the corner that was rotten, but i thought I might aswell try to learn on a car that will be getting used and abused anyway, so i gave this a bash too...
Open to any critism, guys on here have done this along time before me, so open to any pointers you may have for me!
Re: Sj 410 project
So today i got the arch finally all seem welded along the wing, and finishing off the weld on the patch at the rear would of got more done but i ended up giving my neighbour a hand with a van.
Tomorrows plans are to finish off the arch on this side, box it in, and join it into the floor where the bulkhead to the pickup bed will be going back in. Might even try get a start on the next side too
Hopefully it stays dry so i can get the sheet steel outside to cut it!
Re: Sj 410 project
So today I actually got done what I wanted to, still need to position and seem weld the inner part of the arch which hopefully I can squeeze in tomorrow between dropping a pals wheels off in Hamilton and I get a strange feeling the misses may have said a while ago she has a doctors appointment i've to take her to...
But anyway, some pictures...
Re: Sj 410 project
Need to go get more gas tomorrow before I can do any more, but today I got the arch finished off apart from a very small patch I need to cut and weld in place, amazing feeling seeing one side done, has motivated me to get the rest finished all the quicker!
And that's me now up to my latest progress, must say having the one arch done on that side has certainly given me the motivation to fire through the rest of the sj now, would love any pointers and/or guidance from people if they see anything from the pictures...
Re: Sj 410 project
So with the arch all finished, I started to move towards the front on the same side, found some rot where the floor goes into the rear bed
So cut it out and plate a new plate in...
I was hoping to get onto the holes in the driver foot well once I had finished that, but the car obviously had other plans, as i've discovered this rot, some of it even where the seat mounts are, so i'm assuming i'll be best to cut out the seat mounts out, replace all the metal around that area and then reweld the mounts back in place...
And it's even started rotting below the seat belt mount :( Glad i've found it though, just a pain to get into with the grinder, open to any suggestions!
- donkeychomp
Re: Sj 410 project
Thanks mate, my first time welding thin metal and on a car, so appreciate feed back on itdonkeychomp wrote:Tidy. Neat welding too.
But with this being an off roader and not having to be 'show quality' I'm using it as a learning curve
- RickUK
- Can I have a tow
Re: Sj 410 project
I really admire someone who can weld and do body work like that,i dont have a clue,wish i had taken lessons years ago but not at my age.I can do all the mechanical work but even that prefer to get someone local to do that as well.
Great work
Great work
Deceased.
Current wheels.
Current wheels.
Re: Sj 410 project
Thanks a lot mate, not fancy getting a welder and just teaching yourself?RickUK wrote:I really admire someone who can weld and do body work like that,i dont have a clue,wish i had taken lessons years ago but not at my age.I can do all the mechanical work but even that prefer to get someone local to do that as well.
Great work
I learnt basics of mig on thick metal while I was at college, but it wasn't really part of my course, just always had an interest in it, but I'm really enjoying it, and a lot of the time it usually helps when I'm out on the rig anyway
