That's 1 cool looking Kja!! Look forward to seeing come alongmike harris wrote:Then I bolted my axles in !!!
Mikes lwb build and repairs !
Re: Mikes rotten Kja PROGRESS !!! :)
- mike harris
- SCUK is my life
Il try and keep this updated as I go through it
- mike harris
- SCUK is my life
Got more done yesterday
So nearly finished the rear winch tray, got a few small bits to clean up then that's done, remade the front where it had bean butchered.
Tower have been cut off completely now and cleaned.
Next up I need the bumper of the red car with the missing link rest pads to mock them up, red cars bumper is bolted on, this will be bolted and welded this time. Also going to fill up the 4 holes in and also chop it a bit. Put different recovery eyes in too which will be more useful than the current hooks it has.
Once that's all on and mounted il clean the entire chassis and prime and paint it, except from where the towers wil go, I have to put them on when the body and front end are on to get them in the right place.
Still also have to inline the rear shock mounts, but it's on hijet way now !!
Got to take a day of work to get it over to the blasters, had a look at the rot I need to fix and it's very easy. Shouldn't take long I hope. Rot in the bed isn't great, but I have the panels I cut out to use, should speed things up a bit
- mike harris
- SCUK is my life
Got the front bumper of my red truck last night going to mock that up tonight and finish the rear lashing rings in the rear cross member
Il add pics later on
Mike![:) :)](./images/smilies/icon_e_smile.gif)
Mike
- mike harris
- SCUK is my life
going backwards with this one!!
what's happening?
- mike harris
- SCUK is my life
Currently looks like this
- image.jpg (296.11 KiB) Viewed 7564 times
- mike harris
- SCUK is my life
Front bumper mocked up and bolted into place ready for seam welding
- image.jpg (152.13 KiB) Viewed 7562 times
- image.jpg (551.14 KiB) Viewed 7562 times
- mike harris
- SCUK is my life
Chasis repaired at the front back to standard but a lot stronger I hope
- image.jpg (221.02 KiB) Viewed 7561 times
- mike harris
- SCUK is my life
Recovery eyes both in the back of the chassis
22mm thick
22mm thick
- image.jpg (304.24 KiB) Viewed 7560 times
