Interior light question
ipbr21054
Post by ipbr21054 » Fri Mar 20, 2015 4:16 pm
Many times i am in & out the GV and need to leave the rear door open.
I like to switch off the interior light both up front & in the rear.
I would like to cut into the wiring & add a switch & place it on the dash,this then would allow me to just flick the switch & either make or break the circuit allowing the lights to work or not.
Do you know where i can cut into the wiring,i have looked at the fuse box under dash on drivers side but dont see a fuse marked interior etc.
There is a dome fuse but also on the same circuit as the radio so no good.
Any advice would be great.
Thanks.
Grand Vitara,54 plate,2000cc,Manual,5 Door,Air Con,4WD.
courior
Re: Interior light question
Post by courior » Sat Mar 21, 2015 2:08 am
I presume the rear door has a door switch? can you just replace the door switch with a manual one that u can choose "open" or "close"?
Maruti Gypsy MG410
Electric Fan upgrade
5 speed box
30" Insa Turbo Saharas
1.5" Shackle Lift
LWB Pickup Conversion
Daymaker led lights
ipbr21054
Post by ipbr21054 » Sat Mar 21, 2015 9:55 am
Thanks,didnt think of that.
courior
Post by courior » Sat Mar 21, 2015 7:06 pm
No worries :)
Maruti Gypsy MG410
5 speed box
1.5" Shackle Lift
Daymaker led lights
