My 4 speed sj410
hucky
My 4 speed sj410
Post by hucky » Sat May 29, 2010 1:48 pm
well after lots of messing about with the guy i was buying my sj off, he "found the keys"
so today i took a battery and looked at the car thats not been used for 3 years now i been told.
with out changing the battery it fired, ran and spat its dummy out on the first turn.... then a few more goes and its fine... didnt even need fuel or battery lol... stood for 3 years and its goin :)
Re: My 4 speed sj410
Post by Tramp » Sat May 29, 2010 2:02 pm
welldone, sounds great we need some pictures now!
hucky
Post by hucky » Sat May 29, 2010 2:52 pm
their will be some up very soon
dominic
Post by dominic » Sun May 30, 2010 11:30 pm
Nice one,
yer photos please.
Dom
8-)
Currently Drive
SJ 410 Q 1985 (GREEN)
VITARA GL+ 2017 (SILVER)
hucky
Post by hucky » Tue Jun 01, 2010 12:12 pm
well as promised...
pic whore time :)
i have tow bar and some wheels to be fitted.
i need a new hood, or as ide prefer to do, make something for the back and make a removable hard top...
other issue i have with it at the minute is it needs 2 door handels and and its very hard to put into 2wd. 4h and 4l are nice and smooth, but 2wd is a little hard to select
Post by ScottieJ » Tue Jun 01, 2010 12:47 pm
Just the usual rust patches then :lol: doesn't look too bad to repair though!
put some fresh oil in the tbox and it should help free it up after a little run.
hucky
Post by hucky » Tue Jun 01, 2010 1:16 pm
thank you... where do i access the oil part on the transfer box? to drain and refill
Post by Tramp » Tue Jun 01, 2010 1:25 pm
hucky wrote:thank you... where do i access the oil part on the transfer box? to drain and refill
there is a drain bolt on the bottom, it will either be a square drive recessed bolt or a hex head bolt with a little gaurd in front of it,
to fill it up refit the drain bolt and then from inside, remove the 4 posi drive screws which hold the gater and metal window down (around the 2 box gear stick) then when its lifted there is a fill point on the top of the t box if i can remember rightly, (i suppose you could always fill up through the gearstick opening anyway) there is also another point on the side of the t box which is a 'fill level' If you know how much you are putting in you don't need to use it but if your guessing just remove it and fill until the oil starts running out of the oriface,
I think the capacity is here on the site somewhere (found it Transfer Box 1.4 Pints 0.8litres), I used ep90,
It looks like you have a decent sj there, They all rust in those place but I'm sure its mostly superficial, It would look 100 times better with a new canvas on it, keep up with the pictures there is nothing better than a good project,
Luke
hucky
Post by hucky » Wed Jun 02, 2010 9:19 am
colour idea i am going for is black, purple and white...
also have found a hood thanks to henry the hover... cheers fella and see you soon
hucky
Post by hucky » Wed Jun 02, 2010 3:35 pm
today i recieved a new bonnett of the guy that i have bought the sj off, who already wants it back now ive cleaned it up a bit.
but here you go
also decided to keep the badge, so had a play
