G box to Pug 1.9TD enigne?
- d_r_1989
- Winching along now
Re: G box to Pug 1.9TD enigne?
Yep that was me, not been on there for a loooooong time! Seems dead compared to this forum! Ill be changing it in a couple of weeks time. Once i get all thd rest of my million jobs done! It drives quite well to bd honest, gears seem to be suited for it. When i had thd samurai transfer box and samurai diffs it was happy on the motorway, now its not so much but i have changed the transfer box for a 410 and using sj413 diffs. Still does over 70 now and happily sits at 50.
Anton i dont think iv actually made a build thread! I best get one made and back dated with pics.
d_r_1989 wrote:Anton i dont think iv actually made a build thread! I best get one made and back dated with pics.
- waynesworld
So which Vit gear box ( bell housing really ) can i use with the Pug 1.9 TD engine, I see the commercial will go but they had the XUD 1.9 N/A ?
What i am getting at, will both diesel Vit bell housings take the XUD 1.9 TD enigne.?
Mite of found one and need to make sure its the correct one for the engine.
- d_r_1989
Commercials are turbo just very very slow. Don't think estates will as they were Mazda engines I believe. To tell if it's xud it will have starter motor on top passenger side, so top right of gbox if your looking straight on.
- waynesworld
Do the 1.9 vit/pug engine comes as called a HDi aswell.
just a quick look on Wiki, they didnt do a 1.9HDi.
- d_r_1989
Pug hdmi has same bell housing but pretty sure they didn't do a hdi suzuki.
Dont know if you know already, but waste veg and hdi don't mix
They do if you *carefully* make the waste veg into biodiesel.
You have to do it carefully, not just dump lye into it and stir - you have to balance the PH levels so that it's not acidic or alkaline, and then it should be ok to run through your fuel tank.
Still, it's a lot more work than just straining it through an old sock and dumping it in your fuel tank!
When I was running my old xud pug I had a shed just big enough to have a settle tank and a few 20ltr pots so no chance of bio for me, that and I was too lazy
So when we got a hdi I still tried wvo, and it all got messy
- waynesworld
I used to run WVO in my 28.TD shoggy, filter to 1mic then just just dump in the tank or 50/50 if below 5degC ambient temp, this will also work i believe on a HDi but only on a twin tank set up.
A bit of hassle but whe i was getting good used veg oil at 25pl it was worth it.
