Pump ?
Re: Pump ?
Filter? give it a clean, might become obvious
Re: Pump ?
Yes that's the fuel filter.
As far as I can see your looking for what was/is the pink & black wire.
- Vitara SPI Wiring.jpg (678.33 KiB) Viewed 4267 times
Re: Pump ?
thanks Darrell,that mean I don't need a filter then,, when I went today and had a look there were a few pink wires, but I have bean doen a bit lookin about n its the relay with the green plug going into it so I will check for the pink/black wire on that one , thanks mate
Re: Pump ?
You will need a fuel filter.
Injection systems normally use a filter after the pump.
I don't know if you could use the original filter before the new pump but I doubt it.
Yes the fuel pump relay is a green plug
Re: Pump ?
righty o I shall sort one of them out aswell , spot on mate thanks for the help hope to get it all sorted this week
Re: Pump ?
The fuel pump relay and main relay are the same, the fuel pump relay has the pink wires. The relays are usually marked 31850-80C10, which is actually a Samurai part number but they are a common part.
