Starting problems ????
Re: Starting problems ????
I think someone mat have cut it off cos av got nout is it on the same loom as everything els mate
Is it not just an earth wire to the bulkhead?
This it what i was reading underneath theat picture ,
- image.jpg (132.5 KiB) Viewed 6326 times
Only had 1 wire on mine
Orighty , well i will try it to see if it sorts the problem out , cos i dont have a clue lyk
Hope it goes welllukey4x4 wrote:Orighty , well i will try it to see if it sorts the problem out , cos i dont have a clue lyk
Thanks mate me to lol
The wiring has changed over the years, you should be able to see if any wires have been cut off, there should be at least one.
Ok thanks mate , am off work tomoz so will be checking then , when i put the loom round engine bay i double checked n there were no wires left so probs bin cut off lyk
Managed to track down the missing wires that were taped up to the loom connected them up n. Fired right up without cutting out after turning key back so problem sorted , thanks for the help
