Rear lower control arm
Kevitara
Post by Kevitara » Fri Jul 08, 2016 5:35 pm
The one that the spring seats in...
Does anyone know if the later models are the same as the earlier ones? I.e. Are they unchanged throughout the 2005-2015 range?
Also, are the Petrol versions the same as the DDiS?
i need one as it has a hole, for my 2006 DDiS and can see some later ones for sale...
All advice appreciated.
K ;)
2006 DDIS Grand Vitara 5dr
Kevitara
Re: Rear lower control arm
Post by Kevitara » Fri Dec 23, 2016 6:31 pm
Just for the record I bought a 2011 model part from a breaker in Lithuania and it fits fine. The old one had to be cut off as the pivot bolt had seized in the bush. Other than that it was pretty straight forward.
K
